New Clutch
Old Aug 6, 2008 | 10:14 AM
atv gooroo's Avatar
Default New Clutch
I just ordered a new clutch for my 05 Sportsman 500 HO due to some cracks in my old one. I was wondering on if the new clutch comes balanced. I know that the original clutch was balanced because when I went to change the clutch spring people kept after me to mark the cover when I took it off so that I could put it back on the same way because it was balanced. I have to install my original spring and weights because the new clutch does not come with them.(why?) That is what concerns me because, how did they balance it without all the parts presant? I also would like to know if the assembly comes assembled or do I have to get it pressed together.
Old Aug 6, 2008 | 10:57 AM
colt2245p's Avatar
Default New Clutch
IT SHOULD COME FULLY ASSEMBLED all you will need to do is change out the weights ....didi you just get the primary or is it a complete kit with rear pulley and belt?
Old Aug 6, 2008 | 11:13 AM
atv gooroo's Avatar
Default New Clutch
I just ordered the primary. What about it being balanced? I know that I am probably being **** as usual.
Old Aug 7, 2008 | 12:24 AM
Default New Clutch
Older ones had X's bottom and top,new one May not have X on top cover,just etchings. After installing spring put back on AS was when received. X marks are the alignment position. Etching should line up with x at bottom,Or if you really are **** make your own marks! Good luck
Default New Clutch
Old Aug 7, 2008 | 12:26 AM
Default New Clutch
Think I'm seeing DOUBLE! No now tripple! Sorry
Old Aug 7, 2008 | 05:39 AM
MaineWheeler's Avatar
Default New Clutch
Getting old OPT-lol-they say the eyes are the first thing to go. Hey thanks for the help the other day answering my questions it was very much appreciated.
Old Aug 7, 2008 | 02:28 PM
jeffls's Avatar
Default New Clutch
Your new clutch will have an "X" on the spider and a grouping of numbers stamped in the cover. these align on top of each other for proper assembly. Many people just take a black marker and mark them before taking the cover off to make is even easier.
The clutch is balanced without any internals (weights/spring) when manufactured. Just install your components and you're set.
A new replacment clutch doesn't come with any weights/spring because even within a certain class/model of machine, there are several different clutch set-ups used.
Old Aug 7, 2008 | 05:02 PM
atv gooroo's Avatar
Default New Clutch
Thanks yall. I hope the new clutch makes it in by the weekend.
Old Aug 7, 2008 | 05:06 PM
user493's Avatar
Moto Psycho
Default New Clutch
Gooroo, I bought EBS clutches for a non-EBS Sportsman 500 a long time ago. I actually still have them. Both clutches had several holes drilled in the edges to balance them. I don't image they ever QUIT balancing them.
