Is this common for an new 800
Old Aug 13, 2008 | 08:13 AM
  #21
Koerbs's Avatar
Default Is this common for an new 800
Thats what I thought, but I was under the impression that when submerged it would hold water.
Old Aug 13, 2008 | 08:20 AM
  #22
stendori's Avatar
Super Quad Patrol
I'm watching you!
even the new 400 is way hotter for the wife then the 450 was. i think you need to paint the pipes w/ real good heat paint before you would wrap them for sure.
Old Aug 13, 2008 | 11:28 AM
  #23
HIGHOCTANE's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Koerbs
Thats what I thought, but I was under the impression that when submerged it would hold water.</end quote></div>
That is why I said if it gets wet make sure you run the engine long enough to dry it out prior to storing the ATV. I guess it might be an issue if the ATV is stored out side in the elements and the wrap gets wet from rain. In that case though alot of components will probably rust. Exhaust, due to the heat, is always prone to rusting unless it is Aluminum or Stainless Steel. Speaking of which the exhaust on the new XP's looks like stainless. That would be sweet if it is! My ATV sleeps in the garage, which has a dehumidifier. One of the best things you can do,along with keeping the oil changed IMO is store the machine out of the elements.
Cummins Driver
Sep 11, 2019 01:22 PM
toonces
Dec 15, 2015 03:59 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
Oct 10, 2015 10:20 AM
Jason Richards
Sep 4, 2015 06:17 PM
