scrambler 90 will only idle.
Old Aug 19, 2008 | 09:33 PM
Skeetersdad's Avatar
Default scrambler 90 will only idle.
I bought a used 2002 sportsman 90 for my son. It ran great for a couple of days then went to idle and now will not accelerate. I cleaned the carb several times to no avail. I checked compression and it has 90 psi. Starts on first kick and acts like it wants to accel if you pump the throttle. Any help would be great.
Old Aug 19, 2008 | 09:44 PM
Could be time for a fresh top end if carb and air filter clean and wont accept throttle.
Old Aug 19, 2008 | 10:24 PM
Funny thing is this happened the day before and I cleaned the carb then it went to running great again. Talked to the previous owner and he said it would usually run after a carb clean and sometimes ran after just letting it sit.
Old Aug 19, 2008 | 10:39 PM
COULD be LOOSING compression when warm? Could have too much piston to cylinder clearance,runs good until warm? IF you have to constantly clean carb, Is trash or water present,did you flush tank? Just a thought,the time it takes to remove and clean carb,cylinder should be cool,then after running a while does it bog and die?
exmotocrosser
Sep 13, 2019 06:12 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Minimod
Sep 10, 2015 08:03 AM
