2005 Polaris Sportsman 700 - seems to be slipping
I just purchased a used 2005 Polaris Sportsman 700 with EFI. I rides nice other than at initial take off. There seems to be a delay when I hit the throttle. I am not sure if it is a belt problem or if it needs a clutch alignment.
Any help would be appreciated.
THANKS
THANKS
Thanks for your quick response.
It doesn't seem to be a engine problem. At Idle the RPMs are around 1300 and as soon as I hit the throttle they go to 3000 but it doesn't take off right away. The engine speed itself goes up smoothly without hesitation but it doesnt move. I am guessing it is a belt problem but can use any help.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
ITS NOT REAL OLD TO MAYBE NEED A CLUTCH,I HAVE A 01+ THE KIDS THAT HAD IT BEFORE ME BEAT THE HOLY SNOT OUT OF THIS...OPEN IT UP+ SEE WHAT COLOR PRIMARY SPRING.MY NEW RACE SPRING I JUST GOT GOES WAY OVER 2000 RPM'S BEFORE IT STARTS TO MOVE.THE STOCK ONE WAS JUST ABOVE IDLE--1300RPMS.LOOK AROUND,IS THE BELT WORE+GLAZED ON THE SIDES?
bzdok1234
30
02-23-2016 01:55 PM
ranvette
07-04-2015 06:13 PM
