700 Sportsman 700 4x4 -Need help
Old Sep 28, 2008 | 11:14 AM
GIB.2000's Avatar
Default 700 Sportsman 700 4x4 -Need help
MY SPORTSMAN WILL NOT STAY CHARGED AND THE RPMS ARE NOT SHOWING? CAN SOME ONE TELL ME WHAT I CAN DO TO GET THE RPMS TO SHOW AGAIN.. ALL OTHER INDECATORS SHOW. (TIME, SPEED ECT.)
Old Sep 28, 2008 | 08:22 PM
Could be just battery wont hold charge(how old is it?usual life about 3 years depending on how maintained) Or may not be charging(should be 14-14.5 volts while running) Possible speedo internal problem/ First disconnect all power at battery,see if speedo works correctly? Other members may have had same problem,may give better advice! Good luck
Old Sep 28, 2008 | 08:28 PM
GIB.2000's Avatar
THANKS FOR THE REPLY.. WELL THIS IS A NEW BATTERY. WEL THOUGHT THAT WAS ALL THAT WAS WRONG WITH IT. BUT THATS NOT IT.. THE BIKE IS A 2007. THE RPM JUST SHOWS 0 AT ALL TIMES..
Old Sep 28, 2008 | 10:19 PM
700 sportsman's Avatar
have you checked all the fuses and stuff
otherwise i'd guess it was something in the spedo
Old Sep 29, 2008 | 08:39 AM
GIB.2000's Avatar
All the fuses where fine but we changed those anyways.. Do you know what we can do if it is the spedo? Is that something we should take it in to get worked on or is it something we can do at home? Thanks for your time..
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
