2002 polaris sportsman 500 speedo problem?
Old Oct 1, 2008 | 09:26 PM
manxman's Avatar
Default 2002 polaris sportsman 500 speedo problem?
I baught a 2002 polaris sportsman 500 and the digital speedo does not work or the needle is this common and is there a fix.I am going to order a manual for it but until it comes in I thought I would ask around any info would be appreciated.The odometer shows the miles on it but thats it no needle movement or digital read put.?????
Old Oct 1, 2008 | 10:27 PM
If speed or miles not registering,but rest of speedo works,then just probably bad speedometer sensor located on right front brake caliper, runs up to speedometer,small plug in connector. #4010298 sensor with connector
Old Oct 2, 2008 | 07:49 PM
manxman's Avatar
Thanks I'll have to take a look at it going to have a good look at it saturday have to put a rear cv boot on first then I check that sensor.I've ordered a book should be in 5 days good thing to have.Thanks for the help I'll let you know if thats the problem.
skittero
35
Mar 1, 2019 12:39 AM
gfl0224
Jun 27, 2015 06:52 PM
yellowpolaris
Jun 21, 2015 11:13 AM
Dakosk
Jun 6, 2015 05:37 PM
May 27, 2015 11:15 AM
