ETC Adjustment on SP335?
Old Jan 31, 2001 | 09:44 PM
Buckeye400EX's Avatar
Has anyone tried to adjust their Electronic Throttle control on a Sportsman, or any other Polaris that has this? TOP SPEED and I mean TOP SPEED on any surface is 35mph on the under-horsepowered, fat SP335. But the quad just doesn't feel like it's revving out. I wondered if there's some hidden power to be unleashed by adjusting the throttle. Signed, Mr. Shoulda-got-the-SP500. Thanks!
Old Feb 1, 2001 | 09:35 AM
floodrunner's Avatar
You can and should adjust your ETC but I doubt that's the source of your top end problem. You should have 1/16” to 1/8” of play at your thumb throttle. Peeling back the rubber covers on the throttle sheath (just down from the ETC box) will expose the adjuster. Back off the lock nut and screw or unscrew the adjustment to take out/ increase the throttle slack. All this does is increases or decreases the length of the throttle cable sheath. Usually you need to increase it to compensate for cable stretch.
Some make this adjustment by using a 1/8” hex key as a feeler gauge between the contacts inside the ETC box. With flat screwdriver carefully pry the cover off the box and you’ll see the contacts. I disable the ETC on my machines as improper adjustment can cause backfiring. If my throttle ever freezes up I know where the kill switch is.
Old Feb 2, 2001 | 08:05 PM
SuperDuty335's Avatar
I have mine set at less than 1/16". It became out of whack a while back before I knew what it was and my 335 would barely run.
Old Feb 2, 2001 | 10:09 PM
I haven't had the chance to look at mine yet, but thanks for the detailed response floodrunner and the suggestion on 1/16" Super. I'll let ya know if I find out anything earth shattering.
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Whitelx1
Oct 2, 2015 10:55 PM
wrencher82
Sep 30, 2015 04:27 AM
r1pilot83
Sep 27, 2015 07:38 PM
