Lift Kits for 2008 700 X2
Old Oct 20, 2008 | 08:40 PM
ZAKAZIM's Avatar
Default Lift Kits for 2008 700 X2
I am not one for lifting my ATV but I'm tired of high centering my ride. This past weekend I did this 3 times in water just over 10" deep folowing a budy on his 800 Sportsman that is stock and he just cruises through. With the longer wheel base and the added tonage, I think this must be the Issue best I can figure. Question 1 would a 2" lift help? 2nd I have looked all over and can not find a kit available for my 2008 700 X2 .
Old Oct 20, 2008 | 11:40 PM
Evil Genius's Avatar
I added 26" tires which gave me a little more clearance:
Old Oct 21, 2008 | 01:31 AM
H20's Avatar
H20
I agree I don't think there are very many companies offering lifts for these machines. One problem is the macpherson strut front suspension.
I also am running 14" wheels and 26 inch maxxis bighorns and I have not ran into any trouble yet.
Old Oct 21, 2008 | 10:56 AM
OIown12's Avatar
Larger wheels and tires will give you a little room. I found this at Highlifter.com. It should work perfect for you. Includes relocation bracket for rear suspension and spacers for front.
Good Luck!
Old Oct 21, 2008 | 10:57 AM
G.A.S.'s Avatar
Go with bigger tires nd rims. THe stock carlisle 489's are suppose to be 25 inch tires but mine seem to measure more like 23 1/2". With a lift you have to worry about the added stress and the angles of your driveline geometry. Tires will give you an increase in ground clearance.
Old Oct 21, 2008 | 11:39 AM
bluequad03's Avatar
Haven't looked at it close, but this might work.
http://www.rubberdowncustoms.ca/x2.html
Old Oct 22, 2008 | 01:05 PM
SCRAMMYTODD's Avatar
I would recomend bigger tires and a rubberdown lift personally. RD is great to deal with and bigger tires with a little more aggressive tread will help the most.
Old Oct 22, 2008 | 02:02 PM
firehog's Avatar
I have the same atv. I have 12" rims with 27" tires. Ground clearance has not been an issue for me, even with the very large ruts left behind by 4wd trucks!
Old Mar 21, 2009 | 06:29 AM
ZAKAZIM's Avatar
Thanks all.....
The bigest thing was finding the kit for the 08 X2' the 07 and under were out there to buy but not the 08 kits. I found a kit this week and put it on last night and it fits well. I got 2" lift in the front and 1 1/2 in the back. http://stores.ebay.com/Super-ATVs is were I got it. The bets part of it was that it got the sag out of the front tries were there not bowing in on the top anymore. The kit was under 100.00 bucks so if it becomes an issue with the drive line I will take it off but I did not see a big CV angle change with the 1 1/2".
Old Mar 21, 2009 | 10:20 AM
When you get the big meats on the quad take a pic for us. I'd like to see how it looks.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
rgjackson
Sep 23, 2015 01:53 PM
poutlaw525
Sep 9, 2015 03:19 AM
