2000 magnum 500
Old Oct 28, 2008 | 09:27 PM
PK Hawkshaw's Avatar
Default 2000 magnum 500
runs up to 25 mph like it is under a load. Give it to much gas and it back fires through the carb. this atv is only used on the farm, does a lot of pulling jobs
thanks
ken[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 28, 2008 | 10:04 PM
ftwflh's Avatar
Check the secondary clutch buttons before any thing
Old Oct 28, 2008 | 10:34 PM
ncriderforks's Avatar
have you checked the simple things like air filter and air box? Have you made ANY mods to it at all?
Old Oct 29, 2008 | 11:55 AM
got know clutch that i know off
thanks
Old Oct 29, 2008 | 11:59 AM
its got a new plug, air cleaner, oil and filter. The only thing i did not check was for water in the gas and i am going to do that right now.
Old Oct 29, 2008 | 01:37 PM
eggenz7's Avatar
your quad has two clutches on it. its in the black housing right by your left foot. primary (drive) clutch in connected to the motor and the secondary (driven) clutch is connected to the gear box.
Old Oct 29, 2008 | 08:58 PM
thanks EGGENZ7, what would i be looking for when i check them, can a clutch make the engine get louder and back fire thought the carb.
Old Nov 11, 2008 | 08:38 PM
gdeddy's Avatar
I am having the same sort of problem with my500 magnum. It starts, idles, and runs slow great but when I try to go faster it bogs down and backfires.
Old Nov 11, 2008 | 10:30 PM
IF backfiring through carb and no power,check cam for exhaust lobe damage or wear.OR could just need carb work?
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
