recoil starter R&R
Hard to do but you must hold shaft inside recoil in a vise and then are able to unscrew plastic reel. Be CAREFULL not to break the small tip off the shaft that holds the small spring! I've done this several times! If able to get pulley off then can remove internals to get to main spring. Good luck
kbazzy
Sep 26, 2015 11:26 AM
