Solenoid Test
Old Nov 6, 2008 | 01:32 PM
Volnut17's Avatar
Default Solenoid Test
05 Magnum 330
How can i tell/test if the solenoid (by the battery) is bad?
I just bought a new battery. Cleaned all the cables.
And My tach and display is not coming on.
Could it be the solenoid or something else?
Old Nov 6, 2008 | 01:50 PM
MECHANIKE's Avatar
welcome to the forum,use a screwdriver to cross the two posts where the batt+starter is hooked, if spins starter solenoid good.look at wiring for display and tach,not related
Old Nov 6, 2008 | 02:03 PM
Volnut17's Avatar
I have tried the screwdriver bypass. And it does spin the starter. So then that is good?
But why would I not get anything to come on at the Tach? Should I be getting any readings from voltmeter at the key switch?
I also have another issue with the fan. WHen the battery is connected the fan comes on without the key switch on. I have ordered a new "transmister" which I believe controls when the fan cuts on and off. Would a bad transmister that creates a "overheating" light to blink cause the lectrical system to shut down?
Old Nov 6, 2008 | 02:55 PM
02magnum500's Avatar
Gets his share of deer.
Could it be an ECM issue?
Old Nov 6, 2008 | 04:50 PM
MECHANIKE's Avatar
the thermister turns the fan on and off.it is not going to activate the fan while the switch off.like magnum said, could be ecm or ign switch related.check wiring.
Old Nov 6, 2008 | 04:58 PM
Volnut17's Avatar
I just ordered a haynes repair manual. Then I will double check all the wiring.
Then if all else fails I can take it to the dealer who will be more than happy to take every penny they can. Me and local dealer have never seen eye to eye.
Joe454
Nov 20, 2020 01:19 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
