2005 800 Sportsman Runs Rough
Old Nov 22, 2008 | 09:20 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default 2005 800 Sportsman Runs Rough
yes!! these bikes need at least 12.8 +- volts to keep them running or it will start running like crap. check the voltage of the bike running at idle and then at say 3,000 rpms. you should be pushing at 13.5 and higher. maybe take the battery out and have a load test put on it to make sure its not going bad.
Old Nov 22, 2008 | 09:36 PM
RobD's Avatar
It will start and run good,,, and if I run it down the road as I stated about 3/4 of a mile to a mile,,, it starts running bad. Once running and turning higher rpms, with no headlights or anything on, will the alternator put out enough to keep it running good? Or does the alternator have to put out enough, along with a good battery, to maintain proper voltage? I will surely check this out. As a matter of fact, when the battery goes dead, if I hook a booster up, it will start, but if I take it off, the engine shuts off right away. I have to elave the charger on it for awhile to get it to start and remain running when the charger is unhooked. I will be going to Sam's Club tomorrow and will see how much batteries are from there. I will let you know if it is a battery problem for sure.
Thanks
Rob
Old Nov 28, 2008 | 01:11 PM
RobD's Avatar
Got a new battery and put it in today. Let it run for awhile, then took it down the road. Well it does the same thing. The old battery was load tested and it was bad. It didnt seem to pop quite as much, but it did some and lost power like before. Eventually I guess I will have to take it in to be looked at and see whats wrong. Will let you all know what was wrong if I find out.
Rob
Old Nov 28, 2008 | 01:31 PM
plumbob's Avatar
Have you checked fuel filter(pn#2520464) or fuel pump pressure at the fuel rail?
SOLOLUCKY
Oct 4, 2024 09:09 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
hoopduerr
Jun 2, 2015 09:01 AM
May 27, 2015 11:15 AM
