Carb vs EFI
Old Oct 14, 2011 | 04:40 PM
  #81
Doctorturbo's Avatar
GOT BOOST!
Emissions
Just as performance can be changed with a few simple environmental changes, so can the emissions output. Carburetors are tuned with screws, where EFI is calibrated digitally. It is difficult for manufacturers to guarantee emissions compliance from mechanical devices that could easily be altered in the field. EFI can compensate for engine wear and degradation over time, where mechanical parts cannot.
Thank you for making my point that carbs won't even come close to EFI emission wise.
Old Oct 14, 2011 | 05:44 PM
  #82
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
you're sniffing some strange glue dude-
time for you to start doing some reading.
Old Oct 14, 2011 | 05:46 PM
  #83
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Originally Posted by Specta
I like your way of thinking.
EFI: like it or not here it is.
lol
Old Oct 15, 2011 | 12:20 AM
  #84
Cranky CJ's Avatar
.......and i just finished reading 9 pages of EFI vs Carb. Haven't read anything that would change my mind on buying either one, in fact I have one of each.
I have a 05 Sportsman 400 carb and 08 Sportsman 500 EFI. Until I bought my used 08 EFI sportsman 500 in July, everything I have (except the 2010 Ford pickup) is carb. My carb'd 98 Vulcan 1500 motorcycle has worked flawlessly since new and I've had it up and over some of the highest passes in Colorado (13,500'), same with the wife's 04 carb'd Sportster 1200. Once I did a carb swap on my 86 CJ7 (to a better off road carb), it functions flawlessly at high altitude. A properly tuned carb runs just fine, starts just fine and works just fine.
Is EFI better? of course. No argument. Newer, more advanced technology that simply delivers fuel better. But, the Carb'd vs EFI argument would not be any kind of deciding factor in any buying decison for me. I'm just not a carb snob. For others, it is a factor in your buying decision.
Old Nov 9, 2011 | 07:55 AM
  #85
Specta's Avatar
Here's my 2012 550 Touring EPS. It's 16ºF this morning.
cold start 11/09/2011 6:30am 16ºF - YouTube
Old Nov 9, 2011 | 08:20 AM
  #86
Yep, when we had a carb. and an EFI model of the Polaris 500 (ATP and Sportsman X2) it was pretty easy to figure out which was which when trying to start them both on a cold day. We've been out on rides when the temps have been down to 10 F. EFI, turn the key, 3 chugs of the starter, idling nicely. Carb., pull out choke, turn key, 5-6 chugs of the starter, running, carefully ease the choke in over the next couple minutes until idling with choke wide open. EFI for me.
Old Nov 9, 2011 | 08:44 AM
  #87
Specta's Avatar
It's nice that it continues to run after its started and I did get on and ride away.
Old Nov 9, 2011 | 09:06 AM
  #88
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
nothing likes to run when it's 16* out.
it is a nice comfort being able to start the motor up in 3 chugs and walk away and hear it purring like a kitty.
My efi rotax twin will fire up in half a chug when it's 10* out.
Old Nov 9, 2011 | 09:27 AM
  #89
Specta's Avatar
I was happy that it even started.
Old Nov 13, 2011 | 01:52 AM
  #90
bigcam400's Avatar
at 16 degrees i dont care if itll crank,..i ant gettin on nuttun an ridein away that cold less its got a dern good heater!!
