HELP***Dropped gas can nozzle into Sportsman gas tank
Old Nov 15, 2008 | 02:00 PM
scramblerXrated's Avatar
Default HELP***Dropped gas can nozzle into Sportsman gas tank
since you drained the gas already, remove the tank and turn it upside down. you should be able to grab it . i cant believe no one suggested this.
X
Old Nov 15, 2008 | 02:06 PM
JCDEYO25's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: scramblerXrated
X</end quote></div>
stendori did suggest that at the top of the thread
Old Nov 15, 2008 | 02:13 PM
upnort's Avatar
since you drained the gas already, AND save removing the tank get a buddy, turn whole machine upside down and shake it. Actually think the grabber would work depending on the size of it. Mine has come in handy pretty often. Since don't have one the remove tank would probably be more feasible.
Old Nov 15, 2008 | 02:29 PM
600Grizzly's Avatar
You could probably do it with 1 coat hanger. Just cut the hanger so you have two straight lengths then bend a tight hook on the end of each one. use one to arrange the nozzle so you can put the other one down inside the spout. Use the second one so you can lift the nozzle a small amount then hook the far end of the nozzle with the hook on the one you put down the spout. Use the two to guide and lift the nozzle out. Just make sure you turn the hook away from the wire you mentioned. Good luck fishing.
Dave
Old Nov 15, 2008 | 02:49 PM
  #15
fatnbald's Avatar
Claw gripper like that is a dollar store item here. You could also try a smaller hose duct taped to a vacuum cleaner hose. Possibly trap it that way.
Old Nov 15, 2008 | 08:13 PM
  #16
calley's Avatar
thanks to all for your suggestions!! went to a home depot today and they didnt have a grabber...gonna try a few more stores tomorrow and I am going to stand the machine up on it's ***. Just curious...how hard is it to remove the gas tank? (I'd love to get an XP - just need someone to lend me the coin!)
Old Nov 15, 2008 | 09:55 PM
  #17
JCDEYO25's Avatar
I had the tank off mine last year...It's not hard to take it off....
John
Old Nov 16, 2008 | 08:13 AM
  #18
stendori's Avatar
Super Quad Patrol
I'm watching you!
the time you spend trying to find a grabber(not a bad idea but still takes time) you could have had the tank off and back on. just my opinion.
Old Nov 16, 2008 | 09:54 AM
  #19
calley's Avatar
Thanks Sten...where do I start if I wanted to remove the tank? I dont even know where to start...
Old Nov 16, 2008 | 11:39 AM
  #20
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: JCDEYO25
John</end quote></div>
since he just did it we'll let john tell you from first hand knowledge.
