wheel studs help!
Old Feb 3, 2001 | 11:56 PM
xplore50097's Avatar
I need to find some place to get longer studs for my new aluminum wheels.any body got any ideas
97 500 explorer.
help help!! I check all over,but no luck.
Any helpful leads thanks
peter
Old Feb 4, 2001 | 10:19 AM
DieselPro's Avatar
If you find any, let me know!
Old Feb 4, 2001 | 10:53 AM
If I find any I will post when, were and how.
Some body has to have some.It just a FRIGGING STUD!!. But it is stopping me and others from
putting aftermarket wheel on are quads and that pi**es me off. When you call the company and they say we just sell the wheels, the short stud are your problem not ours! this is what burns my s**
Thay allredy knew that I would need new studs be for I got the wheels,but did't tell me till I called back. WHAT UP WITH THAT!!! PS NICE WHEELS WISH ICOULD PUT THEM ON ,.SORRY JUST VENTING
PETE
Old Feb 4, 2001 | 03:35 PM
Farmr123's Avatar
Hot Seat sells longer studs as part of a kit to add spacers between the stock hubs and rims. I think they are included in a kit with the wheel spacer, but you might be able to talk them into selling just the longer studs. Unless they would be too long. They are 1 1/2 inches longer than stock, according to their book. They are at 651-982-0600 or www.hotseatperformance.com
Old Feb 4, 2001 | 03:45 PM
THANK YOU FARMR
BEN THER DONE THAT
WATING FOR A YES OR NO.
THANKS FOR YOUR HELP
PETE
Old Feb 4, 2001 | 05:10 PM
DieselPro's Avatar
As long as they are full thread, they will work. best way to shorten would be on a lathe for a neat cut.
I haven't been to the auto parts houses with a sample yet either. I figure 1/4" extra is all we need!
Old Feb 4, 2001 | 06:36 PM
Jack's Avatar
A good aftermarket repair shop will have several types of studs. I found sme that orked perfectly. It's important to get the right type to fit your hubs so they won't turn when you want to remove the wheels. But really, the stock ones work ok, you only get about 3/4 of the stud, but they do work. I have a couple of machine that have been like that for several years with no problems at all. Never a problem, so why worry about the length of the studs??? the wheels won't come off. Don't worry about it and change the wheels.
Old Feb 5, 2001 | 08:52 PM
Jack what auto parts store did you find wheel studs for a sportman in . I know that we can run the wheels with the studs being short,but if you try to tighten them a little to tight they strip.NOT SO GOOD AT THE PULLS WHEN YOU ARE IN THE FINALS AND THE WHEEL STARTS TO COME OFF
WITH 1300 POUNDS OF SLED BEHIND YOU 4TH PLACE SU*KS D.N.F
THANK YOU YOUR IN PUT Any info is welcome
pete
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
