NEED HELP
Old Dec 2, 2008 | 07:57 PM
  #21
ftwflh's Avatar
Default NEED HELP
That is your counter balance and you need to check the vent line going to it.
Old Dec 2, 2008 | 08:29 PM
  #22
00polarbear's Avatar
Default NEED HELP
what do i need to look for on vent line?
Old Dec 2, 2008 | 08:33 PM
  #23
ftwflh's Avatar
Default NEED HELP
make sure it is open.Keep an eye on this because if it ruins the bearing it is $$$$$$$$$$$$$$$$
Old Dec 2, 2008 | 08:39 PM
  #24
Default NEED HELP
what do i need to look for when checkin out the vent tube?
Old Dec 2, 2008 | 08:42 PM
  #25
Default NEED HELP
disregaurd the repeat... going to check it now
Old Dec 2, 2008 | 09:08 PM
  #26
Default NEED HELP
vent tube apaers to be fine lil dirty but can still blow threw it ok?
Old Dec 2, 2008 | 11:37 PM
  #27
Discovery's Avatar
Default NEED HELP
All Oil Attracts moisture and with out sufficient heat it just collects. Example: Grandma drives to the supermarket that is only 1 mile away, that is all the driving she does and after a 1 year Period she never makes the 3K oil change interval she will have a large amount of water from condensation in the engine oil. with out sustained operating temperature drive the water just collects.
Old Dec 3, 2008 | 03:04 AM
  #28
user493's Avatar
Moto Psycho
Default NEED HELP
Isn't there only supposed to be as few ounces of oil in there for the counter balancer?
Old Dec 3, 2008 | 11:55 AM
  #29
scrambler400enoge's Avatar
Shapeshifter Rider
Default NEED HELP
<div class="FTQUOTE"><begin quote>Originally posted by: 00polarbear
what are some things that would cause water to get into the oil?</end quote></div>
cracked case[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Dec 3, 2008 | 08:21 PM
  #30
RticKwad's Avatar
Runs Stealth!
Default NEED HELP
would he need to do the kerosene to cycle all of that out?
R'
