hockey puck lift spacer
Old Jan 10, 2009 | 10:20 AM
Bodangles's Avatar
Default hockey puck lift spacer
Man, that is awesome!. I will be doing that to my 700. I have mudlite tires on the front and they rub all the time. Couple of questions though.
- What diameter pluming tube is that?
- What kind of washer is that? (What size and where to get it. part# if you have one.)
Old Jan 10, 2009 | 10:44 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
lol. i did the same idea and it cost me less then $5.00 at the local hard ware store w/ alot less work using the cpvc pipe and fitting . looks good though for sure and much cheaper then buying new springs.
Old Jan 10, 2009 | 12:36 PM
MECHANIKE's Avatar
actually if you bring the strut closer to the end bumper it will bottom out shorter,made me think though considering its completed.........
Old Feb 12, 2009 | 12:07 PM
zooman's Avatar
Hey Quad 4 how is the lift working out? This is exactly what I need to do my 06 sportsman. Do you happen to have the part numbers for the two washers? I have found my dealer up here pretty useless and the part number would help alot.
Thanks
Matt
Old Sep 15, 2009 | 10:37 AM
  #15
Dande's Avatar
Can the pics be sent to me, all I see are red X's... and I want to add height for winter driving in snow. I'm so tired of getting stuck and at my age I don't have the energy to get un-stuck more than 1 time...
Old Sep 15, 2009 | 08:03 PM
  #16
RticKwad's Avatar
Runs Stealth!
Same here only RED X's, maybe include the web link (photo bucket, web shots etc.)
Thx,
R'
Old Sep 15, 2009 | 08:20 PM
  #17
UTU's Avatar
UTU
I think the pics are in his album in his profile(:>
Old Sep 15, 2009 | 08:32 PM
  #18
Scalerman's Avatar
Quad 4
Nice lift. Not sure how the pucks will stand up.
Here's my 2006 Sportsman lift.
Used 2" inside dia. pipe and had 3 pieces of 1/2 square stock wielded on.
Helps to have a friend who can wield, especially for free (:-).
Pipe is cut 1 1/4" long.
Had to grind out about 1/8" of the inside of the 1/2 square stock to make it fit
around the outside of the stock springs.
This really helped out the front / \ tires.
Rides a little stiffer, but steers better and has better ground clearance.
I measured from the ground to the fender at the tire hub and gained about 2 1/4"
Paid about $4.65 at the scrap metal yard for the pipe.
4J's post about Polaris HD Front Springs Installed has great directions and Pic's.
Look on the SEARCH.
Here's a couple of Pics.
Scalerman
Attached Thumbnails hockey puck lift spacer-500-001.jpg   hockey puck lift spacer-500-002.jpg
Old Sep 15, 2009 | 09:25 PM
  #19
RticKwad's Avatar
Runs Stealth!
TO EACH HIS OWN, I reckon?
But for me I think just adding HD Springs to the front Vs. all the welding, drilling etc. is a much more robust way to go unless you are really really trying to save $45 dollars and a 1/4 increase pass 2" in the front. - IMO
My only complaint here is compensating for the rear setup to better center the quad. Anyone dones these things to the rear? And what were your results?
Thanks,
R'
QuadRiders
Oct 22, 2015 04:13 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Cantbuytime
Aug 16, 2015 09:13 PM
chuck1177
Aug 11, 2015 03:22 PM
