Need mechanical help from Polaris Mechanic for 07 500EFI
After a rollover and breaking out the Speedo Gauge my machine starts and will not stay running nor will it idle. I can pump the throttle as it is running and that is the only way it will stay running but will not rev up. I can spray gas into air cleaner intake when air cleaner is out and it will rev up. I pulled the injector out and made sure there was gas getting to fuel rail when pump comes on and there is. One person told me you need the Speedo on for it to run fine but I took one off my 800EFI and it still does same thing and the 800 runs fine without the speedo on it. Any advice???
THE MACHINE WILL NOT REV UP AT ALL, NOT RIDEABLE. Polaris Mechanics have you seen this before? I've never heard of the injector going? Will not idle or start unless i pump throttle and keep puming to keep it running but it runs like garbage. Tried new gas, made sure gas was getting to fuel rail and pressure checked incoming fuel to rail. Machine only has 350 miles on it.
