2002 Sportsman 500 HO light problem
Old Jan 9, 2009 | 07:12 AM
BigRawJ's Avatar
Default 2002 Sportsman 500 HO light problem
As in a previous post, my quad took a submarine ride, breaking through some ice and going into the water. I got everything good now except the AWD light on the switch doesn't come on in AWD. Also, the blue light doesn't come on when my high beam is on. Both the AWD and the high beam lights work, just no indicating light on the switches. Are these bulbs you can replace? Is that the problem ya think after it be submerged? Thanks
Old Jan 9, 2009 | 07:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i beleave you can buy replacement bulbs. you have power to both?
Old Jan 9, 2009 | 07:19 AM
BigRawJ's Avatar
Yep they both work fine , just no indicator lights.
Old Jan 9, 2009 | 07:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
just make sure theres no corrsion from being in the water as well. not sure if you could take an ohm meter and test them, but sounds like if there both working(having awd and high beems) then they must be burned out. just a thought as well check to make sure your bike isnt over charging by using a volt meter on it if you can. seems weird to have both the bulbs burned out.
whitty
67
Feb 24, 2021 02:52 PM
jayking232003
Dec 4, 2019 09:38 AM
AtvManiac78
Jul 11, 2015 03:20 AM
gfl0224
Jun 27, 2015 06:52 PM
