2004 Polaris HO leaking oil into recoil starter
Old Jan 12, 2009 | 06:33 PM
JCasper's Avatar
Default 2004 Polaris HO leaking oil into recoil starter
Thanks, but I think I have the manual at home in the fourwheeler
Old Jan 13, 2009 | 01:04 AM
JCasper's Avatar
Tonight I pulled the plug off the bottom of the recoil housing and drained out the oil, it seemed pretty watery.
That brings me to another question. Why is there even a drain plug there? Is it there just in case of a water crossing and it gets water in there?
Old Jan 13, 2009 | 06:58 PM
JCasper's Avatar
I just talked with the service manager at the local dealer
He says there is a gasket and a o-ring in there that could be leaking.
$40 for parts including oil to refill or $160 total if he does it.
Not sure which way I am leaning yet.
Old Jan 13, 2009 | 07:30 PM
onesavage's Avatar
Just do it yourself.Then you know it done and done right.Unless it still has warenty,then let them do it..Simple
Old Jan 14, 2009 | 11:22 AM
  #15
JCasper's Avatar
That's what I'm leaning towards right now
I need to pick up some more Torx bits to remove the floorboard and then I'll start tearing it apart.
Old Jan 19, 2009 | 03:05 PM
  #16
JCasper's Avatar
does anyone know what the thread/pitch is in the 3 bolts in the flywheel?
I need to pick up some bolts today so I can use my puller and get the flywheel off.
Old Jan 27, 2009 | 05:51 PM
  #17
JCasper's Avatar
I have changed both seals and changed the oil and filter.
I'm ready to go riding and see if it's all better now.
Old Jul 31, 2017 | 12:38 PM
  #18
pjwitt1978's Avatar
did you fix the leaking oil into recoil?
Old Jul 31, 2017 | 03:29 PM
  #19
user493's Avatar
Moto Psycho
He hasn't posted anywhere on the forum in 8 years and may not be here any longer. Sometimes a lurker can surprise you but most of the time if they go that many years without posting they're gone for good.
tweeder
Jul 5, 2015 01:57 PM
Shifts
Jul 3, 2015 07:59 AM
bikedad3
Jun 29, 2015 08:58 AM
yellowpolaris
Jun 21, 2015 11:13 AM
