Clutch kit & Dyno-Jet info
Old Jan 14, 2009 | 08:26 PM
Just-gittin-started's Avatar
Default Clutch kit & Dyno-Jet info
Im about to buy a clutch kit and a dyno jet kit for my 08 Trailblazer,I was wondering if anyone had installed either one of these themselves. I dont have a lot a experience working on atvs, and I was wondering if this was something I could do with just ordinary tools or if I should try to find a professional to do the job. I just hate to pay all that extra $$$$$ if it is something I could handle. Thanks for anything you can tell me.
Old Jan 14, 2009 | 08:50 PM
onesavage's Avatar
I have done both on a 99 trailblazer and were not hard to do..Just remeber to lay everything out in order as it comes apart, this will aid big time in asembly.Should not take more then a hour each to do.You do not need a clutch puller , you can "clutch " the primary on the bike and the secondary clutch will come right off(it's not pressed on).If your old enough a adult beverage or six always helps out.
Old Jan 15, 2009 | 03:06 PM
ftwflh's Avatar
RcR or HPD is the place to go for a pipe,jetting,AND YOU WILL need a clutch kit too
Old Jan 15, 2009 | 06:23 PM
firehog's Avatar
I have seen some good instructional videos for clutch replacement, etc. posted on youtube.
Old Jan 15, 2009 | 08:25 PM
Thanks alot guys, I appreciate it.
Lou Domenech
Sep 11, 2015 06:35 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
