2003 330 trailboss front sproket
Old Jan 14, 2009 | 11:59 PM
jsgot14u's Avatar
Default 2003 330 trailboss front sproket
Ok.. So a friend and I were riding ATVs today. He was on my Polaris and hit a small bump, gunned it to pop the front end and all I here is a loud click and him saying "WTF HAPPENED??!??!"
Come to find out my front sproket broke, slipped, fell off.. Im not exactly sure.. I have the service manual and it doesnt show a pic of the spoket and how it should look when installed properly. However it does show the sprocket and some type of nut that holds it on...
Well there is only about an inch or so of a metal piece for this to sit on, the teeth is only on the outer 1/4 inch, I have not seen this "nut" and I do not believe that both of them woudl fit even though it it needed.
Can someone give me a clue as to what I am actually suppose to do with this... I can work on ATVs, bikes, and cars no problem.. So if you can get me a pic or tell me what I am in need of doing, I can do it.. And would greatly apreciate it.
Thanks
Old Jan 15, 2009 | 09:20 AM
Sandman2.0's Avatar
Go to bikebandit.com and look at the parts schematic. I'd also recommend getting a service manual for it. I got one for mine on a CD from ebay.
Old Jan 15, 2009 | 09:21 AM
Takes an 11 tooth sprocket and a snap ring that sits in a groove on the shaft to hold it in. Probably broke the snap ring which could have let the sprocket slide too far.
Old Jan 15, 2009 | 09:28 AM
scootergptx's Avatar
Supersock
Hired Gun!
Yep, sounds like the snap ring left the building. Check the case for any damage the chain might have caused too.
The parts diagram will help a lot. And the manual. But, I just looked through my Trail Boss service manual, and they were very lacking in that department.
But I've changed the front sprocket on mine, and it's a very easy job. You may want to check the rear sprocket for wear, and replace the chain.
Got a really good deal on all three for mine from a seller on ebay that goes by sledpartsguy. Very good price as well.
Old Jan 15, 2009 | 09:37 AM
Supersock
Hired Gun!
Here's a link to a parts diagram. As far as ordering from this particular company, I never have. Just the site has my dads name, so it's easy for me to remember.
Parts diagram
Old Jan 15, 2009 | 03:01 PM
ftwflh's Avatar
one reason to be sure the chain is propperly adjusted.That is what causes this to happen
Old Jan 15, 2009 | 09:56 PM
jsgot14u's Avatar
cool.. I apreciate the help.. Yea I have a service manual.. But as you said, it lacks in the diagram department.. I will try out the snap ring idea.. Thanks and will let you knwo if anything comes up
Old Jan 18, 2009 | 11:38 PM
jsgot14u's Avatar
ok, so come to find out.. the output shaft in the gear case is broken. I have to replace it as well as the other materials..
Any suggestions on resonable parts... I have found the cheapest is $117... let me know if you guys have any suggestions
slowgsxr97
Mar 18, 2022 03:40 AM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
95wolv
Jul 17, 2015 08:13 PM
