1999 Trail Blazer warm starting problem
Old Jan 18, 2009 | 06:44 PM
erichead's Avatar
Default 1999 Trail Blazer warm starting problem
Hello,
I have a 99 250 Trail Blazer that will start just fine when cold but is very hard to start when warm. Has good fire and is getting fuel. The only way I can get it re-started when warm is to take the plug out and burn it off with a lighter, it seems like it is flooded but not sure.....not sure if the lighter really helps, may just be coincidental. One other thing, I thought it was the carb...not the case, the carb is clean.
Tim
Old Jan 18, 2009 | 07:08 PM
eggenz7's Avatar
did you check your float level? if it is slightly off it will let fuel run into the cylinder. also check your choke cable free play. should be 1/8" of movement on the end of the chock lever before it moves the plunger
jace
Sep 10, 2020 08:30 PM
Big600twin
Jun 10, 2015 03:01 PM
1000gade
May 27, 2015 12:37 PM
covert
Apr 29, 2000 09:54 PM
97TrailBlazer
Dec 6, 1999 10:33 PM
