XP owners! Is an oil change easy on them?
#21
<div class="FTQUOTE"><begin quote>Originally posted by: TLC
Does removing the oil filter act like removing the a drain plug as well? I like that idea ,two steps in one.</end quote></div>
No, I think the oil plug is right there by the oil filter.
#23
<div class="FTQUOTE"><begin quote>Originally posted by: DCT
TLC,
Actually, I like the filter in that vertical position rather than a horizontal position for a couple of reasons.
However, contrary to what others might say, I've talked to a guy who found a couple of nasty "dents" in the bottom of his when he changed his oil and filter on his XP the first time. So, I'm going to "think a little further" into this. LOL
That guy has already taken preventative measures with his. If I get one, I will too, as I'm one of those "lucky" ones. LOL</end quote></div>
Keep thinking. [img]i/expressions/face-icon-small-wink.gif[/img]
TLC,
#24
I can see a aftermarket company making a heavy duty rubber or plastic plug that covers the oil filter hole ,that you just push on and ply off to remove again.
Like a larger stronger version plug the rust proofing places use to cover the holes they drill in your car or truck to spray oil into body panels.
#25
Like a larger stronger version plug the rust proofing places use to cover the holes they drill in your car or truck to spray oil into body panels.</end quote></div>
The guy that had dents in his oil filter made a swing away 1/8" metal plate for his.
#26
<div class="FTQUOTE"><begin quote>Originally posted by: Roofer
Keep thinking. [IMG][/IMG]</end quote></div>
I will... better than sitting somewhere on a trail with stream of oil behind the ATV and a blown motor just because I listened to someone else who thinks that everything Polaris makes is perfect. [img]i/expressions/face-icon-small-smile.gif[/img]
#28
Well, I have an XP with a few miles on it in the woods. If I was in the rocks and had an XP, I would maybe think different. If I had anything else, I wouldn't worry about it. [img]i/expressions/face-icon-small-smile.gif[/img]
#29
Not sure how you can think crawling underneath a ATV to change a oil filter is a nicer place for maintenances. The old location on the side of the ATV was as easy as it could get.
</end quote></div>
It is easy imo...less messy too..no need to crawl under..you can reach it from the side quite easliy..I have a creeper I lay on.....to get any easier the oil would have to change itself..lol..
I'm not sure what some you guys want...NOTHING is perfect in everyones eyes..everything is give and take and a choice has to be made...
I wish the few guys on here who have such great ideas about ATV design would get together and design and build a machine..if it is as perfect as you seem to expect these machines to be and priced competitvely I'll buy 2..
I agree that the filters exposure could be a concern..but mainly I think t will only be a concern with rocks..I don't ride rocks normally but one place I plan to ride has alot of them..hence the reason I am hoping for a good aftermarket skid..If none are available before I go I will make protection of my own...it is not that hard to do...
</end quote></div>
#30
<div class="FTQUOTE"><begin quote>Originally posted by: HIGHOCTANE
</end quote></div>
Amen!
</end quote></div>
Amen!
