Winch issue
Old Jan 21, 2009 | 07:07 PM
SageBoy's Avatar
Default Winch issue
Greetings,
While plowing today my Polaris winch decided that it doesn't always retract when asked to. It does eventually but at times it can take up to 15 times of hitting the button before it engages. I checked the free wheel lever to make sure it wasn't in between the free wheel setting and where it should be and it appears to be fine. It goes out with no issues but will not engage right away to pull back in. Has anyone ever seen this before? Would appreciate any advice on how to fix it.
Thanks in advance.
Old Jan 21, 2009 | 08:09 PM
700 sportsman's Avatar
Default Winch issue
Does the cylinoid click, or does the winch try to pull it in unsuccessfully
If it's option 2 you probably have another junk Chinese Polaris winch to add to the huge# of them out there
Old Jan 21, 2009 | 08:28 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
Default Winch issue
This has been a big problem with the Polaris and Warn winches, especially the 2500's. No concrete evidence of what causes it or a fix, just alot of complaining is all I have seen.
With the Warns, some of it was as easy as a new switch. Not sure on the Polaris winch. Probably because they have an over the counter warranty and no one finds out the problem.
Old Jan 21, 2009 | 08:30 PM
jchunn's Avatar
Default Winch issue
If it goes out but not in, it sounds more like a switch issue than a winch issue.
Old Jan 21, 2009 | 08:57 PM
SageBoy's Avatar
Default Winch issue
<div class="FTQUOTE"><begin quote>Originally posted by: 700 sportsman
If it's option 2 you probably have another junk Chinese Polaris winch to add to the huge# of them out there</end quote></div>
The cylinoid just clicks.
Old Jan 21, 2009 | 09:24 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default Winch issue
its most likely the contact switch being bad. if it says polaris and not built for polaris by warn on it its not a warn winch.
Old Jan 21, 2009 | 09:28 PM
Default Winch issue
X2 on the contactor being shot
Old Jan 21, 2009 | 09:38 PM
SageBoy's Avatar
Default Winch issue
If it happens to be one of the possible issues mentioned would it still be covered under the warranty?
Old Jan 21, 2009 | 09:41 PM
Default Winch issue
I really doubt it, but anythings possible
I'd ask, since you got nothin to loose
toonces
Oct 19, 2015 02:21 AM
MNatv89
Aug 10, 2015 02:20 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
