Xp 850 still having brake issues
Old Feb 13, 2009 | 07:17 PM
Daledo's Avatar
Default Xp 850 still having brake issues
So I pulled the tire off the front left and cleaned all the mud off the caliper and rotor, put the wheel back on and tried it out. The right front wheel will lock up as it is supposed to while the left front just grinds and vibrates. Callled my dealer and they said they may can fix it under warranty. If not anyone have an idea of what might be wrong?
Old Feb 14, 2009 | 04:35 AM
Art454's Avatar
Did you try bleeding the brakes?
Bleed them till the fuild is clear and don't let the master run dry as you bleed r breaks
Art
Old Feb 14, 2009 | 07:45 AM
HIGHOCTANE's Avatar
Are the pads worn the same on the left as they are on the right?
Old Feb 14, 2009 | 08:37 AM
DCT's Avatar
DCT
Banned
If it were me, I would jack up the front end, remove the tire, gently compress the caliper, and slowly spin that wheel and see if the rotor is warped. May have been warped from the factory.
Old Feb 16, 2009 | 12:10 PM
Daledo's Avatar
Dealer said both sides were metal on metal and rotors were grooved 170$ just in parts for pads and new rotors.... why would my pads be gone after 300 miles? And I didn't ride around with the parking brake on .. that was their first guess .
Old Feb 16, 2009 | 12:25 PM
DCT's Avatar
DCT
Banned
My first guess would be that the OEM spec from Polaris is leaving too much space between the pads and the rotors. As soon as some dirt or small rocks get in there and you apply the brakes... the rotors are grooved. However, that's just a guess.
Old Feb 16, 2009 | 03:51 PM
Art454's Avatar
That is a complete new machine.....Should have bought extended warranty.
Why I bought the 08 800 a few days ago.
Shoulds like the calpiers are freezing up causing all that wear on the front breaks.
My sales lit says they are using new dual a-arm front suspension.
I would call polaris and see if they can't make it right.
I had a 97 500ho and a 2003 700ho and never had a break problem or any problem as that goes.
Seems like it takes them 2 years to get the kinks outa new machines.
Art
Old Feb 16, 2009 | 04:40 PM
Daledo's Avatar
I have a 2 year warranty and pads are "wear and tear" ... rotors because of the pads.
Old Feb 16, 2009 | 04:41 PM
Daledo's Avatar
Dave, sounds like that could be the case..
Old Feb 16, 2009 | 04:55 PM
HIGHOCTANE's Avatar
That's what I was afraid of and why I asked about pad wear..but I thought uyou might have had a sticking caliper on one side.
Dave actually my pads are pretty tight on the disk...not sure why they wore so quick. I have about 200 miles on mine and only have about .030 cumlative pad wear(ie inner and outer) so about .015 per pad...and I've been failry hard on the brakes.
They aren't real thick to start with..maybe .200? For info the wear limit thickness is .040..
