Sportsman wont "upshift"
Old Feb 14, 2009 | 08:38 PM
wolf6002000's Avatar
Default Sportsman wont "upshift"
New to the forum...I have a 2000 335 and it seems to be stuck in low..however it does have low and high. When in high gear it just revs up and seem to go nowhere.Ive replaced the belt,replced driven clutchw/a used one,the linkage is in order as i disassembled and manually engaged low,high and reverse,I have also replaced speed sensor,now Im at a loss...plaese any advice would be greatly appreciated..Thanx wolf6002000
Old Feb 14, 2009 | 09:16 PM
If talking about Sportsman 335 or even a 325 Trail boss or Magnum, you say you replace driven clutch with a used one,did you check ramp buttons for wear or damage in clutch? Can cause above mentioned problems.
Old Feb 15, 2009 | 07:53 AM
drlang's Avatar
Look at the splines on the aluminum bell crank. If worn they won't push the trans all the way into hi.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
