2008 800efi... check enging light?
Old Mar 30, 2009 | 10:41 PM
markymark72703's Avatar
Default 2008 800efi... check enging light?
Just bought a 08 Polaris 800efi. It's used but not much, only 32 hours on the machine. I got it home and after unloading I noticed the check engine light came on the instrument cluster display. I checked and it didn't have an owners manual anywhere. Any ideas on what I should check? I know most of you will say take it to your dealer but if there is something I could check before loading it up I would like too.
Old Mar 30, 2009 | 11:05 PM
plumbob's Avatar
Does it still run like normal?If it does then try disconnecting the ground off the battery for a few minutes then hook it back up to let the system reset.If that doesn't work then put the tranny in park,turn the key on then turn the key off and on 3 times in less than 5 seconds.The word "wait" will show on the screen.The check engine icon will blink once,pause,then blink twice to start diagnostics.If a code exists it will blink.Example:for a code 31 it will blink 3 times then pause and blink once more.When it's done it will blink a code 61.
Old Mar 31, 2009 | 05:23 AM
700 sportsman's Avatar
Here is the link http://www.mediafire.com/download.php?nwnjhtuznmw, to the polaris service manual for your bike, and the password to download is Polaris
Old Mar 31, 2009 | 09:12 AM
I guess Mozilla doesn'r work with that link, tried IE and got it no problems. Thanks. I'll be checking it out.
Old Mar 31, 2009 | 03:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
find the code and let us know if you want to find our what it is. also go onthe polaris web sire and maybe down load the owners manual
Old Mar 31, 2009 | 04:20 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Unhappy Check Engine Light...........
This is starting to sound like a Automotive Forum...LOL.....
Old Mar 31, 2009 | 04:49 PM
Well I got it all worked out. The problem was the Barometric Pressure Sensor. One of the wires had been possibly pinched from the seat maybe. It was cut in two. I called my dealer and he had on in stock so I got the new one installed once I got back home. My other prob was the back seat. I have an X2. I couldn't get the seat off. I had 2 other guys helping me and it wasn't working. I took off the nut underneath the seat so it lifted ut. I got a grinder and took the shaft that locks the seat into position and made it a little smaller which seemed to work. Now you pull the strap and the seat comes out with no problems. So thanks for everyone's help.
Old Mar 31, 2009 | 04:59 PM
chevyman142000's Avatar
I think they should do a recall on this or something. I believe that is what I had to have fixed on mine and I have heard of other people having the same issue. Glad you got it figured out.
bzdok1234
30
Feb 23, 2016 01:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
D-Hagz
Jul 4, 2015 02:19 AM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
