qustions on 2001 sportsman 500
Old Apr 16, 2009 | 10:32 PM
sk8er289's Avatar
Default qustions on 2001 sportsman 500
i have a sportsman 500, 2002 and i need to replace the sator and have no clue how to and where exactly it is. i also replaced the rear axle and it still clicks when you drive. my speedometer needle doesnt move, it still shows the hours, miles. thank you
Old Apr 17, 2009 | 02:44 AM
chuck_raduenz's Avatar
if the speedo still counts miles and hrs and the needle dont move. your gona need a new speedo. its sealed and you need to break the speedo apart. but upon doing that who knows what else would be broken upon doing that. pluse there are no replacemt parts for it other than either new one, or a used one.
the stator is under the recoil. you will need to remove the foot well, recoil cover and need to get a fly wheel puller to get to it.
are you shure the clicking is comeing from the rear axel? shure its on that side? it might be comeing from the tranny.
Old Apr 17, 2009 | 05:41 AM
mbogosia's Avatar
You can rent a puller at Autozone and it works great. I just did this job last week. Also, I would advise you to take pictures or make notes about where all the plugs go. The whole harness runs up under the hood and there are quite a few connections you need to make. My harness on my new stator was slightly different and I had to make a couple splices.
Old Apr 17, 2009 | 07:18 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure the clicking isnt a bad bearing as some times they will make the same kind of sound when bad. imo
Old Apr 17, 2009 | 07:59 AM
sk8er289's Avatar
Default bearings and stator
how can i tell if its a bearing, or if its the transmission. and is there any special way to do this coil. like when you pull the fly wheel out, do you have to time it or anything. and also when we did the front cv axle, my friend released the shock and its still loose, is there a way i can compress it my self?
Old Apr 17, 2009 | 08:06 AM
TLC's Avatar
TLC
If you have AWD then your speedo is fine. its your "Hall Effect" sensor located the front right disk brake that needs changing .$44.77. easy to change. Part #39
Price list http://www.cyclepartswarehouse.com/f...2001&fveh=5564
Old Apr 17, 2009 | 08:45 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if your shock is loose then your friend put something wrong back together. i usually can tell if a bearing is bad when its apart and i feel how it rolls. hard to tell until its ready to destroy itself and freeze up or come apart. you can jack it up and roll the wheel by hand and listen and feel real closely to hear if its grinding or if its fetching. you guys regreased before you put the boot on right, or did you replace it as a whole unit?
Old Apr 17, 2009 | 08:56 AM
sk8er289's Avatar
replaced the whole thing. we put everything back right with the shock it just needs to be compressed i think
Old Apr 19, 2009 | 10:08 PM
sk8er289's Avatar
Default ??
Cole Hadden
Jun 15, 2025 09:05 AM
Hunter100us
Oct 7, 2015 11:46 PM
Aug 11, 2015 11:56 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
maxjung
Jul 14, 2015 03:10 AM
