Polaris trailboss 350l carb issue?
Old Sep 4, 2013 | 09:58 PM
mudder77's Avatar
A little more info would help.. Has it been sitting up? Have you checked compression? Have you cleaned the carb,air filter ok,etc?
What do you mean by sitting up ? Carb is clean, air filter is new. It idles and runs okay for a short while, but starts to die when throttle is opened, flipping choke lever too first position helps it to keep going.
Old Sep 4, 2013 | 10:19 PM
Flipping the choke open a little to make it run better is usually a pretty good sign it's starving/lean on fuel. Sounds like it's still either carb related,the main jet's partially stopped up, the needle valve sticking or even leaking crank seals or a cracked air box neck can cause a lean running condition. Another thing I'd do is a compression check. If compression is low,(100 psi or lower) when it gets hot rings can loose their seal against the cylinder walls and run crappy.
Old Sep 5, 2013 | 09:56 PM
mudder77's Avatar
Default Trailboss carb problem
Thanks for the tip, would never have looked for leaking rubber connector.
I hope this is the answer, gotta get her going before the snow flies.
Thanks from Mudder77
Dabears1983
Jun 16, 2015 12:17 PM
cornermike
Jun 3, 2015 07:27 AM
gren25
Feb 8, 2001 09:18 PM
RobS
Aug 23, 2000 11:55 AM
willster
Mar 12, 2000 11:17 PM
