Newbie with an oldie and some questions
Hello to everyone, I just purchased a 91 Trail Boss 250 4x4 looks and runs like new original tires have over 50% tread left. I'm not too familiar with the Polaris line but when i saw a 2 stroke 4x4 for under 1500 i had to have it. I'm just wondering what is still available to make some more power and also to replace the stock exhaust as it's the only thing that has rust on it. I saw a DG extreme pipe with silencer that's listed for the 88 to like 94 trail boss 250 but doesn't say if it will work for the 4x4's or not and no answer back yet from sellers website. I have ordered a new set of Boyseen power reeds and also a uni filter just to do some of my own piece of mind maintenence and I was wondering if tis will require rejetting or if I can just retne the carb? Aby info about this wheeler is greatly appreciated.
The only thing I can advise yiou on with this is to keep ALLL the chains adjusted
OK so the Polaris 250 2 strokes don't use a reed cage how does the engine control the induction, sorry this seems dumb but the other 2 strokes i have had all used a reed cage assembly, and I'm stuck on the couch for the next several weeks with a broken knee and torn acl so i cant really go out and pull things apart to get an idea of how it all works i did order a Clymers service manual but hasn't arrived yet. Most of the guys around here are riding newer yamahas and hondas so i have nothing to compare with really. I just want to get a little more top end speed and some more torque as i do a lot of steep hills etc... Any information about the engine and what parts work and will fit the 4x4 (didnt know if the exhausts were the same as the 2x4 designs etc...
You are not going to make this a screamer by no means but it will run respectably with other 4x4s.Aaen used to carry a good pipe for these but with any pipe change you will HAVE to reclutch to the pipe.RcR may still have or be able to make you a pipe.
You will be limited on the gearing on yur 4x4 due to the 3 chain system and keeping the 4x4 working properly.
For some good power advice pm drlang on this forum he used to drag race a modded 250
Hey guys thanks for the info, I found out after doing some research online that Polaris did make a 250 reed engine, just not mine LOL. Like I said I'm off my feet for a while so basically, I am trying to do things to keep me from going stir crazy. The reeds I ordered are Boyseen power reeds and were listed for the Trailboss 250 so hoping I can get a refund. So basically I'm just trying to find out whats out there and what really works. Ive never owned a full auto atv so I have no clue about how the clutching works. The day before I smashed my knee I did a full adjustment of all three chains and also relubed them so thats all good. Im planning on cleaning and rebuilding the carb and as stated before installing the uni filter, was curious if I should remove the foam pre filter from the top of the factory air box as the uni has a 2 stage filter or just leave it alone? And any information about getting new springs to match the pipes or even just general info on how the PVT system works is welcome thanks to everyone here.
