2007 Sportsman 800 Oil Change
Old 05-12-2009, 02:40 PM
buckhard's Avatar
Default 2007 Sportsman 800 Oil Change
Hey all --
Just bought a last of the 2007's 800 Sportsman and need to do first (20h) oil change. Anything special I need to know about changing the fluid on this bike? Did some cruising the the forums and there is a lot of talk about the older sportsmans and having the drain in 2 places, but couldn't really find anything special about the newer style sportsmans.
Do I just need to run the engine, drain the oil out the plug, change the filter, and add new oil?
Newbie here, so be gentle.
Randy
Old 05-12-2009, 02:51 PM
700 sportsman's Avatar
yep, If you want to do a full change, you will need 4 different oils, AGL, Angle Drive Fluid, Premium Demand Drive Fluid, and some 0W-40 motor oil, and if you want, you can get a napa (wix) filter 1356, but for just the motor, yes you just pull the drain plug, change filter, and fill'er up, if your just doing the motor oil, be sure you pull the front drain plug, and not the transmission plug in the back
Also grease up the front prop shaft, and a-arms (front and rear)
Also I PM'd you the link to the service manual, that should explain everything you'd ever need
Old 05-12-2009, 03:51 PM
buckhard's Avatar
I think for now I just need to change the engine oil?
When Should I do the other fluids? (I'm as basic of a rider as you will find)
So there is only 1 drain plug for the oil in the motor and not an oil res on the 2007's?
Thanks
Old 05-12-2009, 05:14 PM
Kerbbirds's Avatar
yep need a 6mm allen wrench a filter and 2 qts of oil.
Old 05-12-2009, 05:47 PM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Plus you need the "little" filter wrench to spin the filter off, tghe Poo dealer will nab for $12, Wal Mart gets $4
Old 05-12-2009, 05:50 PM
Oldman800's Avatar
And be CAREFULL!!!! taking the drain plug out. Many posts about stripping them out.
Old 05-12-2009, 06:33 PM
Thanks
I change mine everyother service, so unless you have alot of miles on it now I wouldn't worry about it
Old 05-12-2009, 09:14 PM
Polaris Sportsman 450's Avatar
I would use ams oil. Or you could just buy the oil change kit from your polaris dealer but i would stick with ams oil. i just use oil filter pliers.
Old 05-13-2009, 05:05 AM
I use filter pliers, simply because I have them, but I have thought about getting the filter "socket" for a 3/8" ratchet
Old 05-13-2009, 06:39 AM
Works great in tight spot, or like me, put about 8' of extensions on the rachet, and sit on my homemade stool, and spin that filter off!! As for the oil, love Amsoil, but normally buy the Poo kit with filter. The big thing to remember is your air filter, got to keep that bugger clean, go with K&N filter 1003, will last the lifetime of the ATV, easy to clean, buy the skin for it too.
Sjrpp
05-02-2023 03:59 PM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
DOC HOLIDAY
07-09-2015 01:09 PM
Sjrpp
07-05-2015 09:04 PM
Quick Reply: 2007 Sportsman 800 Oil Change
