700 Polaris EFI Need big help
Old May 18, 2009 | 04:37 PM
jodaanja's Avatar
Hmmm. Not sure I'm following the chain of events here.......If you put a punch into the threaded hole in the end of the crank, then what hole did you screw the bolt into?
Old May 18, 2009 | 04:40 PM
tcujkb's Avatar
the punch went up inside the clutch and then the bolt was threaded behind it and pushed the punch up into the small threaded hole on the crank.
Old May 18, 2009 | 05:11 PM
HIGHOCTANE's Avatar
Well since you are already in a fix I'm with Sten..tighten the bolt back up against the punch and give it a blow with a hammer,nothing crazy hard. The try tighening a little more,hit with hammer,tighten,hit..the vibration should bring it off. You should find that each time you hit with the hammer the bolt will loosen a little(ie the clutch is coming off). You might be suprised..most time this method works better than just trying to tighen the crap out of the puller and will minize the chances of stripping the bolt or clutch if done properly.
I would suggest a slide hammer puller but that would just beat the hell out of the main bearings and do more damage.
Old May 18, 2009 | 05:14 PM
tcujkb's Avatar
i think that is the approach i am going to try. i'll let you know how it works out. thanks for the info..
Old May 18, 2009 | 05:21 PM
  #15
HIGHOCTANE's Avatar
Good luck. Again don't get too crazy with the blows...remember the crank and mains are taking the brunt of the blow..if you can get someone in there to pull on the clutch while you do it any dampening of the shock can't hurt...
Old May 18, 2009 | 05:23 PM
  #16
tcujkb's Avatar
thanks for the advice and trust me, the friend that got it in there will be there to help in anyway he can..lol hopefully it works.
Old May 18, 2009 | 05:54 PM
  #17
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
Well, kiss the fiber bushings good bye, but Hell, that is cheap reapir if you get teh primary off, make sure you clean the sloppy grease ou of the EBS too, re-pack with fresh grease
Old May 19, 2009 | 05:14 AM
  #18
stendori's Avatar
Super Quad Patrol
I'm watching you!
give us an update on how it went.
Old May 19, 2009 | 05:50 AM
  #19
snowpacker's Avatar
i had a similar problem on a sled clutch problem had to have it electrical discharge it out and retreaded...............biggest problem is with that is had to take motor out of chassis and have the whole motor submerged
Old May 19, 2009 | 11:30 AM
  #20
eric88gt's Avatar
Another technique you can use is filling the hole in the clutch with oil and then screw in your puller or bolt. Basically you're using hydraulics to remove the clutch, this will only work with the wheeler sitting on it's side obviously.... I had a friend who had the same brilliant idea as your buddy, only his was on his sled, he ended up having the cut the clutch off the crankshaft.
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
