1999 500 Magnum 4x4 won't engage
Old May 20, 2009 | 12:01 PM
ATV Connection Mag Forum User's Avatar
Default 1999 500 Magnum 4x4 won't engage
I am not much of a tech, but hoping to fix.
My 1999 Magnum won't engage the AWD. Where do I start?
Is there a fuse I should start with? If so, where is it?
Should I be testing for volts, if so where should I start, go next, etc.
Please be as detailed as posssible.
G
Old May 20, 2009 | 03:03 PM
itch's Avatar
start here
ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Old May 20, 2009 | 03:10 PM
more info:
The machine will engage 4x4 in reverse with the override button on.
The machine will enage 4x4 in high range
The machine will NOT engage 4x4 in low range.
and
The light for AWD comes on Reverse when over held, forward high but not low.
Determined its not the hub. Believe it to be a switch.
Is there a switch somewhere to tell it is okay to engage 4x4 because it is in low range? I am guessing there are seperate switches for High and Low range to tell the 4x4 it is okay engage?
Old May 20, 2009 | 05:43 PM
itch's Avatar
either on the tranny or the shifter itself
Gwolf228
Feb 18, 2017 01:36 AM
rockinkgin
Sep 25, 2015 01:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
Sep 9, 2015 06:57 AM
