700 Sportsman carb fuel problem
This weekend when riding my atv worked awesome for one day. Second day I was riding and after about 6 miles when I went I let off the gas my atv quit and backfired. When I went to go start it, it would not start. After letting it sit for about 15 min it fired right up. It ran great for about 3 min till I let off the gas then same thing. It will run or start up and run fine for about 3 min then start to run ruff and dye like it is not getting fuel. I have replaced the plugs and put in fresh gas. I think it is the fuel pump, however have you quys experienced this before. I think the vacuum fuel pump is not making enough vacuum. Please help me out on this one.
Thanks much
Thanks much
Mine acted similar, tried a new pump, plugs ect, no help, finally saw a worn spot in the breather line from the engine to the air box, removed the whole line, plugged one end and blew through it, it had a pin hole in the rubber hose, replaced that piece of hose and it runs fine again, hard to believe but true, check your vent tub from motor to airbox.
Thanks much
Thanks much
Trooper
