AWD problems
Old May 31, 2009 | 10:56 PM
CATLIFT7254's Avatar
Default AWD problems
ok i changed the fluid in the front end on my X2 and i still have no awd. It is engaging when i let off of the throttle but it will not engage any other time. Anybody know what this is? It is an 07 500 EFI with ADC.
Old Jun 1, 2009 | 07:21 AM
Kerbbirds's Avatar
Unplug the plug in at the diff and see if there is 12 volts going to it, if it has power its probably the cage in the diff is broke.
Old Jun 1, 2009 | 11:41 AM
I just can't see how the cage would be broken, there has been no sign of a mechanical failure. There was no debris in the fluid when i drained it and it never made a hint of anything breaking. The awd went from working to kinda working to doing what it is doing now.
Old Jun 1, 2009 | 04:33 PM
A little more info- the indicator that it is in AWD is coming on and it drives fine, no noise and it is smooth. I will check the voltage when i get in and see what i get.
Old Jun 1, 2009 | 04:39 PM
TLC's Avatar
TLC
Read some of the broken roller cage threads on this site using the "search" option. There is not much warnning or any grinding noise, some had AWD in revese but not in forward because of a bad roller cage,which is odd to me.
Old Jun 1, 2009 | 05:56 PM
OK assuming it is the dreaded cage what am i getting into as far as replacing it goes. I am a Caterpillar lift tech so i have tools and knowledge, should i be worried about this? also should look for a metal one to replace it with or maybe the John Deere parts? thanx!
Old Jun 1, 2009 | 07:19 PM
helmethair78's Avatar
Its cake. Buy the John Deere parts. If you have a manual even better.
check the coil resistance 22.8 - 25.2 ohms
torque cover bolts 14 ftlbs
torque mount bots 30 ftlbs
Old Jun 1, 2009 | 07:30 PM
So the Deere parts will work in the 07? does it matter that it has adc?
Old Jun 2, 2009 | 09:20 AM
My manual is 05-07, and the JD parts worked in my 05. So Im sure they are the same.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
