Trailer for XP's
Old Jun 19, 2009 | 11:53 AM
  #31
Hotdogmb's Avatar
Ruggo, you should have the quads loaded with the XP's in the front and smaller two in the back. You need to have 55% of you total weight in front of the midway point of the trailer. This has been my way of thinking for many years be it single or tandam. Just my 2 cents.
Old Jun 19, 2009 | 12:37 PM
  #32
Ruggo's Avatar
HotDog you may very well be correct. Not sure on the physics of why but I do not doubt what you say. I wonder how it affects it when being towed one way vs the other.
Old Jun 19, 2009 | 01:19 PM
  #33
Hotdogmb's Avatar
If you have more weight behind the mid way point, your trailer will tend to sway back and forth, more so with a single axle. It takes the weight off of the hitch, and sometimes lifts the back of the tow unit up, making for a very unstable towing experiance. Same thing if your trailer is not as level as possible. If the trailer is high in the front, air can get under it and cause it to sway, not unlike when air gets under a Sprint Cup car. If the trailer is too low in the front, you will fell a pushing or back and forth movement on the tow unit. This not only is a pain, but is hard on the driveline of the tow unit. Best thing to do is load your trailer as per normal and measure to the top of the coupler, now measure your tow unit to figure out the lift or drop needed. There are many different lift/drop recievers out there right now to make your towing a happy one. JMO
Old Jun 19, 2009 | 01:44 PM
  #34
Ruggo's Avatar
That all makes sense HotDog! I have heard some of that before. Not sure how much difference it will make with my pickup where the truck is fairly heavy with a long wheel base and the trailer itself has a fairly large spread meaning the space between the trailer axles seems to be large.
Johnny Mac
60
Dec 14, 2019 06:13 PM
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
bigred20653
Oct 2, 2015 10:05 AM
caveeagle
Sep 19, 2015 01:20 PM
