Clutch buttons
Old Jun 27, 2009 | 07:28 AM
meddy293's Avatar
Default Clutch buttons
wondering how long clutch buttons last and how to tell when they're going out? I've got 764 miles on my popo 500 (07)
Old Jun 27, 2009 | 08:00 AM
If you have cover off and are able to check drive clutch,if there is play back and forth on spyder where the 6 buttons glide,then time to replace! If allowed to wear down clutch will start making a rattling noise and worst case when really worn will sound like a rod going out or sound like a diesel!
Old Jun 27, 2009 | 08:25 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
depending if your secondary has a roller clutch vs. having the older style w/ the clutch buttons(sometimes called shoes), the rollers last pretty much a long time and buttons will wear out depending on how much wear in tear like using high range when working it hard instead of low range. opt is refering to the primary clutch buttons that make the rattleing sound. if you have the old style secondary buttons and they wear out it will greatly effect take off and top end perfrocing making it seem to have no power. imo.
Old Jun 27, 2009 | 09:18 AM
HARLEY_OWNER's Avatar
i just had mine done,, i guess the wore pretty bad,, but they make a sound that makes you think your motor is goin out.. all better now... there is still a little sound but he said that they were worn really bad and he did what he could without replaceing everything
Old Jun 27, 2009 | 08:07 PM
meddy293's Avatar
Thumbs up Thanks Guys
Thanks guys for the info on the clutch buttons, good to know info
Old Jun 28, 2009 | 09:49 AM
IamBIGGUN's Avatar
What does it take to replace them? Can I back yard it or does it have to go to the dealer?
Thanks,
Kevin
Old Jun 28, 2009 | 01:19 PM
Thanks,
Kevin
You have to have a clutch spyder tool to loosen up the clutch so you can spin off the spyder. Unless you plan on doing all your own work,just pull clutch with Polaris or equivalent puller and let dealer replace the 6 buttons. On secondary NON EBS or EBS clutches you can replace the ramp buttons or rollers at home,but a manual recommended.
Old Jun 28, 2009 | 03:58 PM
IamBIGGUN's Avatar
I've done all the work so far....I'm not afraid to do it and I like the idea of controlling when it's done instead of waiting for it. How much are the tools? Do you think it's worth the investment? If it's gonna be about the same price at least I own the tools then.
Kevin
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
black_thunder
Sep 7, 2015 01:24 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
