Running Rich!! How do i get it leaner!
Old Jun 27, 2009 | 10:16 AM
HARLEY_OWNER's Avatar
Default Running Rich!! How do i get it leaner!
ok so i got my carb fixed,,, there was some mudd in the bowl.. so i cleaned it all out..
it runs good.. seems a little slow.. but now i want to get it to run a little leaner.. the plug when i changed it was really sooty and black... and when reving it you can smell the gas and a little smoke from it running so rich.. i have some sea foam and i didnt messure it when i put it in there.. but i know thats not the rich problem.. just letting you all know what i have done..
the main jet is a 155..
new plug ( havnt checked it since but you can smell the fuel in exhaust )
new airfilter.. clean solid airbox - carb - and fittings cupplers are all good..
how can i get this beast to run leaner!?!
Old Jun 27, 2009 | 10:18 AM
ok i was reading what you wrote on the other thread.. and i have been reading about dropping the clip? is that under the top of the carb? and if it is sitting vertical.. i drop the clip down 1 knoch?
Old Jun 27, 2009 | 11:40 AM
hey why would there be pressure when i take the gas cap off? is it possible the breather i snorkled up to the pod is pinched in there? i think it is i used zip ties so its possible... would that have anything to do with performance.. or what are some problems that happend with the cap letting out pressure when you open it..
Old Jun 27, 2009 | 12:24 PM
IF there is pressure when you take the gas cap off,check for a pinched tank vent line! Yes it can cause carb problems or rather lack of fuel to the carb until it gets a glug of air! also check for vent obstruction on carb itself!
Old Jun 28, 2009 | 02:03 PM
ok so im gonna try and lift the clip on carb and see if that helps... also i noticed while after hauling like to unload its hard as hell to start.. and even got gas in my airbox.. is it getting flooded or somthing?
Old Jun 28, 2009 | 02:14 PM
hoytultratec's Avatar
sounds like the float is sticking if you getting a bunch of gas in the airbox. or could be set improperly.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
tekrsq
Jun 17, 2015 02:03 PM
robj
Jun 15, 2015 08:45 PM
Chawness
Apr 21, 2000 08:14 AM
