xplorer 400 counterbalancer using oil?
my 96 xplorer 400 has been leaving a few drops of what looks like counterbalancer oil on the garage floor and also seem to be adding to it more often the macine runs great and carrys about 115 pounds of compression, never had any problems with it before i was hoping some of you guys might have some idea's for me
might be a seal or somthing.. somtimes they go out.. i would pressure wash and degrease the motor to find the source,, and go from there.. my bike leaks a little oil.. i dont mind.. its earned the right.. if you wanna fix it maybe suggest doing a rebuild on the motor while your at it.. or just keep an eye on it and top off when needed
MeadowlarkFarm
11-27-2019 08:40 PM
