scramber 400 shifting problems
Old Jul 5, 2009 | 03:47 PM
huntin703's Avatar
Default scramber 400 shifting problems
i recently bought a 2000 polaris scrambler 400 4x4 for $500. however it has a few flaws, when shifting from fwd or rev it grinds real bad not real sure what causes it to to it or how to fix it any advice would help.
Old Jul 5, 2009 | 04:09 PM
ftwflh's Avatar
Easiest fix would be the shift rod out of adjustment or the lever on the tranny stripped or loose.Or even the rpms too high on the motor.
Most likely the shift forks inside the tranny are worn.Not bad to fix just takes time to get it out of the frame.
heath legg
Jul 24, 2015 01:01 PM
hondarider1234
Jul 21, 2015 11:53 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
