Fixing 4 wheel drive and electrical....
Old Jul 9, 2009 | 08:14 AM
jjump's Avatar
Default Fixing 4 wheel drive and electrical....
In troubleshooting my 4 wheel drive, I cam across some additional issues.
The brown w/ white wire coming from the Reverse Speed Limiter looked like it was secure, but it was barely in there. In fact, if I wouldn't have dropped my meter, I probably would not have noticed that it was loose.
SO, I plug the brown w/ white back in, and BANG, the AWD light comes on, and the 4 wheel drive is working.
SO, I make sure all the other wires are tight, so I am wiggling everything around to see if anything is loose, and the engine is running, just lightly tugging at all the wires just to make sure nothing is loose, and ALL OF A SUDDEN, I hear a POP, and the engine shuts down.
I have nothing, no lights, no starter, nothing.....
HOWEVER, the bike will start with the pull start, and the 4 wheel drive does work, but I can't start the bike with the starter, and I have no lights, nothing, but at least my 4 wheel drive works right!!
Anyways, the starter solenoid tests good, 3.4 ohms across the solenoid..
QUESTION - What could have blown that will not let me start the bike, but the bike runs and the 4 wheel drive works with the pull start??
The only thing that resembles a fuse is the 20 amp circuit breaker. I have continuity across this, after I had to cut open the bag around it. But the book says to reset the breaker, how do I do this???
Any other ideas??
JJ
Old Jul 9, 2009 | 09:12 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
What year and make Polaris are you working on?
.......Caper.......
Old Jul 9, 2009 | 10:07 AM
jjump's Avatar
Sorry - 2000 Scrambler....
Old Jul 9, 2009 | 12:29 PM
Well sorry don't know much about them I have the factory Service manual for the 2006 Sportsman line-up...Caper..........
Old Jul 17, 2009 | 11:02 AM
sledman440's Avatar
Default reseting circuit breaker
I found on my sons polaris 400, if I disconnect the battery, then reconnect it, the circuit breaker will reset.
Jmuddin284
Jan 19, 2026 07:16 AM
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
clsharky
Jul 13, 2015 02:07 PM
tporath
Jul 11, 2015 12:31 PM
