Replacment of Sportsman 500 A-frame bushings
Old Jul 14, 2009 | 07:07 PM
nightal's Avatar
Unhappy Replacment of Sportsman 500 A-frame bushings
I am in the process of changing out the worn out bushings and A-arm rod on both sides of my 2000 Sportsman 500. I was reading the service manual to see torque specs and it has a big warning on the telling you not to reuse the bolts that you take off as the locking mechanism was destroyed in removing them and to get new bolts. Is this true or was it just loctite that they use and want to make sure you are using the right kind? If so which loctite grade should I replace it with ?
Old Jul 14, 2009 | 07:15 PM
marc340's Avatar
Change the bolt they use self locking nut that are very hard on the tread.
Old Jul 14, 2009 | 11:26 PM
chuck_raduenz's Avatar
i reused my bolts. when i broke the a-arm rod. and never had any issues. i put about 4000 or so miles without an issue, and sold it last yr. just get blue loctite.
Jmuddin284
Jan 19, 2026 07:16 AM
jettman
Jul 6, 2015 12:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
