Front diff fluid fill tips.
Old Jul 22, 2009 | 11:22 AM
09 popo HO's Avatar
Default Front diff fluid fill tips.
Just thought I'd take a pole to see what people use to fill exactly 5 oz of demand drive fluid into the front diff. It is such a tight fit. My dealer says some guys fill it through the vent line. Anyone have any special method they use. Special funnel or syringe?
Old Jul 22, 2009 | 11:44 AM
switzomatic's Avatar
Default Fill
I use an extra top from an 80W90 gear lube bottle and a piece of clear tubing. Works pretty slick!
Old Jul 22, 2009 | 11:47 AM
09 popo HO's Avatar
How do you know you have the correct amount.
Old Jul 22, 2009 | 12:27 PM
kensey1129's Avatar
Default Hub Fluid
I measure out 5 oz. in something then put in the Hub with a meat injector. Works excellent!
Old Jul 22, 2009 | 03:06 PM
Polarat's Avatar
I use a 6 oz. pump oil can.
Old Jul 22, 2009 | 03:44 PM
quickbiscuit's Avatar
It seems to me that putting in exactly 5 ounces is kind of arbitrary when the correct fill level is even with the bottom of the fill plug (per the service manual). I just fill mine to that level every time and don't worry about the exact volume.
Old Jul 22, 2009 | 04:03 PM
Polarat's Avatar
My front diff leaks (go figure, less than 300 miles) and I just top it off until it starts comming out the hole. Never had a problem with AWD.
robert301972robert
Aug 30, 2015 11:34 AM
NatePerz
Jul 27, 2015 03:27 AM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
