Polaris 500 won't start
Old Jul 22, 2009 | 12:06 PM
scrappy22's Avatar
Default Polaris 500 won't start
Does anybody have a suggestion other than the obvious reason. Has Gas has Spark. Cleaned the Carb. New Parts in the Carb. Has Compression.
Mind Boggled.
Old Jul 22, 2009 | 12:23 PM
HARLEY_OWNER's Avatar
im gonna go out on a limb and say you tryed with the choke on rite?
if you take off the air box and look into the carb... does the slide move up when the throttle is pressed and can you see and gas sprayin up into the carb when you press the throttle?...
only other thing is check every last connection...
oh yea,,,, is the kill switch off... lol just had to throw that in there. good luck
Old Jul 22, 2009 | 01:12 PM
scrappy22's Avatar
Default 2001 Polaris Magnum
Tried the Choke, has fuel in the bowl, the cab has a diaphragm that moved up and down with vaccum only when the engine i running, but replaced the diaphragm, new needle, seat, bowl, cleaned carb and jets. I know is a vaccum on the intake side, it will run if I hold my hand over the carb. Has good compression, it maybe the intake boot will check that, I just am not able to figure this thing out so I post a help cry for other things to try.
Thanks
Old Jul 22, 2009 | 01:44 PM
TDAWGCOUG's Avatar
May be WAY off, but this was my problem and solution this week
http://forums.atvconnection.com/pola...weirdness.html
Old Jul 22, 2009 | 02:33 PM
scrappy22's Avatar
It sucks and my wife is getting ****ed that I am putting money into it put I know its something simple but what. I am going to just drop it off at the dealer on my way to the lake and let them figure it out, it will cost me but it might be worth the headache. I will post what they find wrong, but won't be home till monday to do so.
Thanks
whitty
67
Feb 24, 2021 02:52 PM
MikeyBoyesq
Nov 27, 2020 02:44 PM
neilbedwell
Nov 10, 2018 11:02 AM
Thanos
Jul 12, 2015 08:40 PM
1000gade
May 27, 2015 12:37 PM
