Where is sensor for cooling fan on 04 SP600
Old Aug 27, 2009 | 12:05 AM
WIscrambler's Avatar
Default Where is sensor for cooling fan on 04 SP600
The cooling fan on my 04 Sportsman 600 has been acting up lately. For the past week, it would run all the time when the key was turned on. Yesterday, the fan quit working and the engine overheated(coolant was bubbling). I tested the fan and it is definitely working fine. Where is the sensor that tells the fan when to turn on? There is one on the cylinder near the thermostat, and there's one on the bottom of the radiator. Which one is it? Thanks.
Old Aug 27, 2009 | 09:59 AM
atv gooroo's Avatar
On my 500ho it is on the left side of the engine. If you unplug it the fan should cut on. (2 wire plug)
Old Aug 27, 2009 | 10:46 AM
TLC's Avatar
TLC
That engine sensor works the overheat light the one you want is locted on rad #25 it tell the fan when to turn on or off .
Old Aug 27, 2009 | 12:51 PM
atv gooroo's Avatar
I don't have that on my 500ho. I just have the one on the engine and it does tell the fan when to come on. I see that mine is called the Thermo sensor. I did however know that some models had a sensor on the radiator because people hook up temp gauges there and I wanted to do mine but I don't have one.
Old Aug 27, 2009 | 12:57 PM
atv gooroo's Avatar
I just looked it up myself and TLC is correct. Number 25. It to is called the Thermo sensor.
Old Aug 27, 2009 | 05:01 PM
Thanks everybody. It turns out that the thermo sensor on the radiator had a broken wire. I replaced that sensor, and the fan is working normally now. Part number was 4010161, and it was on back order from Polaris. Had to call about 10 dealerships before I found one!
Old Aug 28, 2009 | 07:10 AM
Kerbbirds's Avatar
You can get them from the parts house, Wells # sw 526, may have to change the ends on the wires. Mine cost like $30.00
Old Aug 28, 2009 | 09:34 AM
TLC's Avatar
TLC
I just notice that, The 05 do not have a rad sensor anylonger, I guess the sensor on the motor works both the overheat light and fan now.
Old Aug 28, 2009 | 09:53 AM
That's great info to know! The OEM sensor from Polaris was $70. I didn't have a choice though since I'm going trail riding tomorrow.
Old Aug 28, 2009 | 02:02 PM
Big600twin's Avatar
Make sure you check the plastic radiator neck and the cap. When mine overheated from the sensor going bad, it warped the neck and I did not get a really good seal and it leaked. I had to replace the filler neck and the cap. Not something you want to find out on the trail.
Jeff Roper
Feb 1, 2022 11:48 AM
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
poutlaw525
Sep 9, 2015 03:19 AM
