Meter reading on coil on 2002 Sportsman 700
Old Sep 8, 2009 | 12:21 PM
SnowDrift's Avatar
Default Meter reading on coil on 2002 Sportsman 700
Does anyone have a service manual that tells what the reading should be coming from the coil on a 700 Sportsman? I suspect the coil to be bad, but want to be sure before I order the new part for $160. Maybe the wires are just bad, although I'm learning the coils on some of these models were known for going bad quickly.
Old Sep 8, 2009 | 06:22 PM
gumbyman's Avatar
STATOR....PULSER COIL (W/R TO W)---185 OHM
(W/R TO GROUND)...OPEN
STATOR....CHARGE COIL ( Y TO Y ) O.43 OHM
( Y TO GROUND)... OPEN
IGNITION COIL.....PRIMARY (0.11 OHM)
.....SECONDARY (6.7 K/OHMS)
hope this helps but if all messed up go to a parts store and buy a 10$ spark gap tester...
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
200es
Jul 10, 2015 09:09 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
