Engine noise please help!!!!
Old Sep 21, 2009 | 08:45 PM
byrdi's Avatar
Default Engine noise please help!!!!
I have a 98 polaris scrambler 400 4x4 and i bought it last year and rarely ride it.... I noticed that the engine has a tick(almost knock) it sounds like its in the front of the engine... Does anybody have any idea what this could be??? Does the crank case on these (2 strokes) have oil??? if so where do i check it?? thanks
Old Sep 21, 2009 | 08:46 PM
byrdi's Avatar
oh and it only does it at idle and low rpm's
Old Sep 22, 2009 | 05:53 AM
uncertifiedmechanic's Avatar
My home made pliers did get the job too.
The tick you mention possibly could be piston slap, and should be addressed right away b4 cylinder out of round occurs.
Old Sep 22, 2009 | 08:14 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I agree with uncertified mechanic, Our 325 magnum has started doing this as well. My mechanic listened to it and said it was most likley piston slap. time for a freshen up. He said I could do it myself for about $200-300 pending on what needs replacing or the shop would be about $700
Old Sep 22, 2009 | 08:53 AM
drlang's Avatar
Check your primary clutch buttons, especially if it goes away above idle. Doc
Old Sep 22, 2009 | 01:18 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
2 strokes dont have engine oil. its mixed w/ the gas and you should have aoil tank in the fron of the wheeler to put 2 stoke oil in. not regular engine oil.
Old Sep 22, 2009 | 08:41 PM
drlang's Avatar
There is oil on this particular 2 stroke, it is for the counter balancer. Look down next to the carburetor there will be a dipstick, it doesn't take much, but it is 30 weight. Doc
Old Sep 22, 2009 | 08:53 PM
ftwflh's Avatar
Ride it until it gets loud enough to find it.Most of the noises you hear will just normal noise
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
