SnowPlow Time...
Old Oct 2, 2009 | 02:45 AM
chuck_raduenz's Avatar
60" will be big enough. 72" mightbe a bit large for larger snow falls. i home built a 54" plow. wish ida made it a 60" now. but my 500 pushes it with ease. i did a few driveways last yr. and aslong as you keep the snow from packing down with the car/truck tracks you will easly beable to keep it clean. if you had a longer drive youd be able to get speed and throw the snow farther.
i also agree with stacking the snow. i did it in town next to the garage as there was no place else to put it. and i got it about 6ft tall tell i took the pile down since it was getting to tall. but good luck.
Old Oct 2, 2009 | 09:46 PM
noooooo's Avatar
I have a 60" moose and a 72" glacier 2. I have not used the glacier yet. No more than I have invested in the glacier ($225 for blade and pushtube NIB) I figured I would give it a try. I would use the moose for sidewalks and deeper snows.The glacier will be used for driveways and lighter snowfalls. I modified the moose to fit to the glacier 2 xp plow mount. I am reengineering my plow angle to use an electric actuator.
Old Oct 4, 2009 | 04:36 PM
09' Sportsman XP 850's Avatar
Does anyone know if a plow and attachment from a 2008 Sportman will fit on my 2009 Sportsman 850?
Old Oct 4, 2009 | 04:41 PM
sportsman to xp parts are not interchangeable. if it was sportsman to sportsman it would. id image if you had the same plow and a a mount on each wheeler the plow would work on either or.
Old Oct 4, 2009 | 08:40 PM
  #15
noooooo's Avatar
The way I understand it the xp mount and pushtubes for the glacier 2 are different than the non xp glacier 2 mount and pushtubes. The bar the pushtubes attach to on the mount plate is bigger diameter and possibly longer.
kampswas
Sep 23, 2015 05:05 AM
hammer4
Utility ATVs
38
Feb 4, 2008 01:59 AM
delta
Utility ATVs
Apr 10, 2002 06:27 PM
Gommel
Utility ATVs
10
Mar 11, 2002 07:54 PM
plowing2001
Nov 14, 2001 07:05 PM
