AWD wires pulled from hub, now what??
If its pulled completely out of the coil you will have to remove metal sleeve and see if there is enough wire to try to repair and replace with new sleeve. Usually have to replace coil,but you can check,PLUS manual recommended as the sleeve has to be siliconed back in and must be about a .001 clearance between face of sleeve and strut inner casting.
Chocobamofo
07-10-2015 07:46 PM
